Problem in porous media recognition in FLUENT |
April 14, 2020, 06:18 |
#21 |
Assam
Rep Power: 6 |
Means for the inlet I have to give the volume fraction for the particles. I will try with this. If I will get something close that would be better.Otherwise we will discuss.
Thanks |
April 14, 2020, 06:54 |
Volume Fraction at the inlet
#22 |
Yes, you have to give a flow rate for the solid at the inlet. How much is needed can be determined from the volume fraction after time T. Assuming flow rate to be constant throughout the duration, you can determine what should be the flow rate for the solids at the inlet.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
October 11, 2022, 11:42 |
#23 |
Hey there,
how did you get succesfull ? I try to validate the Problem aswell, but my particles keep gettin' through the porous domain. Greeting |
fluent 2D axisymmetric with swirl simulation with porous media | user0314 | FLUENT | 1 | June 11, 2015 03:57 |
porous media in Ansys fluent | Suresh Msk | FLUENT | 0 | November 17, 2014 09:09 |
Problem with rhoPorousMRFSimpleFoam and how to define porous media | Amit Mathur | OpenFOAM | 6 | July 18, 2013 07:57 |
Fluent porous media | lostinicem | FLUENT | 3 | January 26, 2012 11:35 |
Porous media problem in 3D | Marijo | FLUENT | 1 | March 1, 2006 18:38 |
