axial piston pump simulation in Fluent
Old   February 23, 2020, 12:08
Smile axial piston pump simulation in Fluent
Silence is on a distinguished road
Hello everyone,
I encountered a problem when I was trying to conducted axial piston pump simulation(just one piston) in fluent, the result of simulation shown in fluent is totally wrong, and I don’t know why, here is my train of thought.
Generally, I divided this simulation into two parts,
First part, slide mesh simulation for piston rotation around main axis. In this section, I deployed the MRF, frame motion, set rotation speed as 157.08 rad/s(1500rev/min), steady calculation;
Second part, dynamic mesh for piston axial movement. After the steady calculation was done, select the ‘Copy to mesh motion’, and change the time type into transient, run.
PS:I had also conducted the simulation in AMESim and Pumplinx, result from this two software agreed well.
Main settings:
1.mesh: mesh model includes two main parts, first, valve plate part which contain two parts, 1--- oil-in part, 2--- oil-out part; second, piston part which also include two parts, 1---piston cap, 2---piston cylinder.
(1) number of mesh: valve plate part, oil-in 19167 cells, oil-out 153169 cells; piston part, piston cap 14800 cells, piston cylinder 50853 cells;
(2) type of mesh: valve plate part--- Tera/Mixed; piston part---hex;
(3) refinement domain: valve plate---damper groove(triangular)
2. Model: (1) Mixture: all set are default;
Main phase, fluid-oil;
Second phase, vapor;
(2) Cavitation model: transition: fluid to vapor, vapor pressure 3540 Pascal;
3.Control Method:
(1) Steady simulation(rotation part): SIMPLE, other settings---all default;
(2) Transient simulation(dynamic mesh part): PISO, other settings---all default;
4.Criterion: all criterion are set as 10^(-5) in both steady and transient;
5.Transient settings:
(1) step size:0.0004,
(2) number of steps:310
6.Boundary condition:
(1) inlet: 0 pascal;
(2) outlet: 0 pascal.
7. UDF code is as follows:
#include<stdio.h>
#include "udf.h"
DEFINE_CG_MOTION(motion1, dt, cg_vel, cg_omega, time, dtime)
cg_vel[1] = 157.07963 * 0.04929 * 0.3639 * sin(157.07963 * time);
printf("vel=%d \n", cg_vel[1]);
Silence is offline   Reply With Quote
Old   February 23, 2020, 12:48
Smile more figures about mesh
every single mesh part has been uploaded as follows.
Old   February 23, 2020, 13:03
Smile settings in fluent
Settings in fluent are as follows.
Old   February 23, 2020, 13:19
Smile result of fluent
settings of monitor, and residuals, displacement, flow rate at outlet, pressure in piston.
besides, I found that in the residual figure, the residuals could not reach the expected criterion in the period that corresponded to the end of one revoluntion, why ?
Old   October 14, 2022, 01:02
Default Nice work
amit kumar
jha.kashyap is on a distinguished road
impressive study! Have you got satisfactory results?
jha.kashyap is offline   Reply With Quote
Old   September 7, 2024, 10:07
Default Axial swash plate pump 3D transient anslysis using UDF
Sandeep009
SKD070809 is on a distinguished road
can we connect to discuss more on linkedIn, since I am also working on same problem.
SKD070809 is offline   Reply With Quote
Old   September 13, 2024, 06:49
amit kumar
Sure, my mail id is jha.kashyap@gmail.com. send me invitation
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
simulation of piston motion inside a hydraulic cylinder mosman Main CFD Forum 0 August 7, 2011 02:40
simulation of piston motion inside a hydraulic cylinder mosman FLUENT 0 August 6, 2011 16:44
Fluent simulation of centrifugal pump yvonne ANSYS 3 January 28, 2010 05:48
Pump Station Simulation GUSU CFX 6 October 14, 2009 07:40
