import chemkin mechanism into fluent
Old   February 23, 2020, 06:07
Default import chemkin mechanism into fluent
Moataz
motaz.medhat is on a distinguished road
Hi all ,
I am trying to import a NH3/H2 mechanism into fluent but an error occurs when i try to import the mechanism and the fluent does not read the species.
I working on partially premixed combustion. The chemikin file is on INP extension and it is already attached.
I need help for importing this file to fluent
motaz.medhat is offline   Reply With Quote
Old   February 23, 2020, 07:13
Default Error
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What error do you get while loading the file?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 23, 2020, 08:36
Moataz
the error appeared as failed to import chemkin mechanism
Old   February 24, 2020, 00:28
samm
Jegan is on a distinguished road
You can check the error in the output file(chem.out).
Jegan is offline   Reply With Quote
Old   February 24, 2020, 05:36
Default chem.out
vinerm's Avatar
Vinerm
As Jegan mentioned, could you find any error reported within chem.out file? As such there does not seem to be any error within the mechanism file provided the thermodynamic database contains all the species. If that is not the case, then the errors will be reported as missing species data.
Regards,
Vinerm
Old   February 25, 2020, 08:03
Moataz
I try to use the mechanism in flamelet of partially premixed model of combustion and the fluent give me the message of failed to import the mechanism. So I can not understand where this chem out I can check the error in the mechanism.
Old   February 25, 2020, 08:11
Default out file
vinerm's Avatar
Vinerm
chem.out and other relevant files, such as .asc, are automatically written in the present working directory. chem.out is essentially a log file with all warnings, errors, etc., which would help with finding the problem. As stated earlier, the mechanism file looks alright. Problem could be with thermodynamic database; may be a missing specie.
Regards,
Vinerm
Old   April 1, 2020, 08:19
Mohammed
Mohammed Alsaffar is on a distinguished road
I need a CHEMKIN mechanism file for diesel and bio-diesel fuels,any one can help plz.?
Thanks
Mohammed Alsaffar is offline   Reply With Quote
Old   July 20, 2023, 18:21
kjde21 is on a distinguished road
Hello, please, I need you to help me.
I'm in the middle of an internship and I'm working on reactive flows.
The combustion model I'm using is partially premixed combustion and I'd like to use the FGM model to represent the turbulent chemical interaction of my combustion. Except that I'm asked to import the Chemkin mechanism, does anyone know how to create it? I've tried to use Chemkin Pro but I don't know how.
It's all about combustion between propane and pure oxygen.
Thank you very much for your quick feedback, I don't have much time left for my internship.
kjde21 is offline   Reply With Quote
Exporting Chemkin Mechanism into fluent skumar112 ANSYS 4 February 9, 2021 11:57
unit conversion of pre-exponential factor A of chemkin mechanism in Fluent newbie FLUENT 5 November 14, 2010 06:44
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 03:22
import fluent cas.gz files bramv101 STAR-CCM+ 0 September 23, 2009 09:28
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
