Continuity equation Convergence issue
Old   February 21, 2020, 00:58
Default Continuity equation Convergence issue
rupak504's Avatar
Lolita
rupak504 is on a distinguished road
I am using Implicit VOF multi-phase model, to simulate a phase change problem. Also, i have a square 2D domain with Non-uniform structured quadrilateral mesh, finer at center and coarser towards ends. I am also using variable Time step size method. PISO for Pressure velocity coupling. and all other at at their default values.
I have given a convergence criteria of 1e-04 for continuity equation and max 200 iterations/timestep, but just after phase change phenomenon, the continuity residual goes up at 1e+02 and gets stable over there.
I don't know what is causing this problem, and what could be the solution ?
any kind of help would be appreciated
regards
rupak504 is offline   Reply With Quote
Old   February 21, 2020, 05:39
Default Domain extents
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Few more details would be more helpful. Is the domain closed or open; what are the boundary conditions? Which mass-transfer mechanism is being used. And is it liquid->gas or gas->liquid mass transfer? If yes, then you have to ensure either the domain is open or the gas is being modeled as ideal gas.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 21, 2020, 07:15
rupak504's Avatar
Lolita
Domain is open from top with Pressure outlet boundary condition. All other sides have No-slip BC. Lee model for pool boiling. Liquid to gas mass transfer.
Old   February 21, 2020, 07:26
Default Time-step
vinerm's Avatar
Vinerm
One possibility is time-step. If the simulation does not converge within 30-40 iterations in a time-step it implies that the time-step is larger than it ought to be. 200 iterations is not suitable. Even if the simulation converges in, say, 80 or 100 iterations, results will appear jaggered over time. Second point is numerics, i.e., space discretization and URFs. If physical setup is good, you will be able to control the run using numerics and time-step.
Regards,
Vinerm
Continuity Equation for multicomponent simulation lordluan CFX 15 May 19, 2020 19:36
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
continuity equation Rafal Main CFD Forum 4 November 29, 2006 10:27
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
