Holes on model in vapor contour when ticking off ‘clip to range’ |
February 18, 2020, 09:55 |
Rep Power: 6 |
When I checked the vapor contour, I cancelled the auto-range, and ticked off ‘clip to range’, then, there are some holes on the model, shown in the figure below, why did this happen? Does it mean that the domain surrounded by holes is the area that cavitation occurs? |
February 18, 2020, 10:32 |
why I cannot insert an image?
Rep Power: 6 |
when I clicked the button ' insert image', there is no reaction, why?
February 18, 2020, 15:59 |
Holes
Contour plots have missing contours only if the clip range is enabled. Else, the contours are plotted everywhere. Another reason for the same is graphics. Sometimes, either due to temporary availability of lesser than required graphics memory or due to some other reason, graphics do not work properly. To resolve this, go to Graphics > Options and change from Hardware Buffer to Software Buffer. Display the contours again.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
fluent, vapor contour |
simplifiedSiwek - error in calculating the position of a coal error | guitar_love_15 | OpenFOAM Running, Solving & CFD | 0 | November 4, 2018 05:06 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 20:42 |
How to model flow through honey holes on surface | lizheng | FLUENT | 0 | July 13, 2000 15:16 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
