Surface bodies to solid body.
Old   February 17, 2020, 11:08
Default Surface bodies to solid body.
KLA
KLA is on a distinguished road
Hi all,
I have a geometry of a wing made of surfaces in catia using multi-section surfaces and fill. I don't seem to be able to transform it to a solid body on ansys fluent.
I tried to sew them using body operation but it always results in a surface and shows a warning: not all bodies could be sewn into a solid body.
Is there any way to transform my surfaces into a solid body?
Thank you all
KLA is offline   Reply With Quote
Old   February 17, 2020, 14:36
Default Wrong Forum
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
I suppose you mean DesignModeler and not Fluent. Post it in the Preprocessing forum.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 18, 2020, 08:48
Default wrong forum
KLA
Thank you vinerm. You're right it's in design modeler. I am new to this.
fluent
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found cdase ANSYS Meshing & Geometry 0 August 26, 2018 15:31
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 12:13
how to move a solid body along a clear line m.r_khani FLUENT 0 November 26, 2011 08:04
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
