Fluid slows down before reaching airfoil
Old   February 16, 2020, 12:11
Default Fluid slows down before reaching airfoil
itb7 is on a distinguished road
To all,
I am trying to run a 2-D simulation of compressible flow past a cone in ANSYS Fluent. However, the air seems to slow down immediately after the inlet boundary for some reason, and I don't understand why. I've included a picture of the issue, and my settings are as follows:
model: realizable k-epsilon, standard wall functions
fluid: air, ideal gas
boundary conditions:
velocity inlet, 375 m/s
walls: no slip on the cone, specified shear of 0 on the boundaries
Any advice on this would be appreciated!
https://imgur.com/a/Qs3FyQ5
itb7 is offline   Reply With Quote
Old   February 16, 2020, 17:14
Default Issues
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The image shows temperature and not velocity, hence, it is little difficult to say whether the flow slows down or not. But there are other settings that imply improper setup. You need to make following changes
1. Use SST k-\omega instead of k-\varepsilon. You may also use SA. If you wish to continue with k-\varepsilon, use ML instead of SWF.
2. Velocity inlet is wrong boundary condition for compressible flows. Use farfield or pressure-inlet or mass flow inlet. Farfield is most optimum.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
fluent
[ICEM] Hybrid Mesh on 2D airfoil Jrmy ANSYS Meshing & Geometry 2 August 14, 2014 16:08
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Fluid structure analysis of 2D airfoil case ahsan_smme.nust@yahoo.com OpenFOAM 0 April 22, 2014 07:12
Fluid Structure Interaction problem for airfoil vinair39 OpenFOAM 0 February 8, 2011 08:57
oscillating airfoil in an inviscid fluid flow S.T Main CFD Forum 6 December 10, 2007 09:07
