wall shear stress determination
Old   February 11, 2020, 06:12
Post wall shear stress determination
ALMANI Sikandar is on a distinguished road
Hello all,
how can I find the wall shear stress in post-processing?
In my case, I have a 3D column(4 mm gap) which has a single bubble having a diameter (3 mm or more) collides when it rises. I have to determine the wall shear stress generated by that bubble on the wall.
is there any algorithm or inbuild way to do so?
ALMANI Sikandar is offline   Reply With Quote
Old   February 11, 2020, 06:25
Default Not a bubble
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
A 3 mm bubble in a 4 mm gap is not a bubble but a slug. You have to use multiphase model, VOF, to predict the shear stress.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 11, 2020, 06:44
Dear Vinerm,
Thanks for replying
the column is wide in the lateral direction.besides that this study is conducted on a smaller bubble diameter than 3 mm too. Yes VOF simulations are already done now I only want an algorithm to find the WSS.
Thanks
Old   February 11, 2020, 06:51
Default Nothing extra required
vinerm's Avatar
Vinerm
If you wish to extract shear stress from VOF simulations, then you do not need any extra work. Shear Stress is reported directly under Wall Fluxes.
However, if you wish to determine shear stress due to particle impingement within a DPM, then you have to do some work; not just on the algorithm or the code but studying some literature on which model can be used to predict quantitative value of shear stress due to particle impingement. It won't be easy because you have to assume wall as a particle and then use mechanical properties of both, particles and wall, to predict the shear stress.
Since the particles in your case are bubbles, I don't think there would be any extra stresses on the walls, rather bubbles will be pushed away due to wall lubrication.
Regards,
Vinerm
Old   February 11, 2020, 06:57
Great
Thanks for the prompt reply vinerm.I will be back to you soon.
Regards
ALMANI
cfd - post, vof multiphase, vof simulation, wall boundary conditions
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Wall Shear Stress prediction varies with fix y+ Jeeloong FLUENT 0 November 24, 2016 18:17
different order for wall shear stress result in steady & unsteady simulatiom raminostadi FLUENT 0 October 1, 2016 12:23
Wall shear stress in channel flow sreeyuth OpenFOAM Running, Solving & CFD 2 September 5, 2014 11:02
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 15:41
