SIMPLE and COUPLED Scheme for Dual Rushton Stirred vessel flow field simulation
Old   February 10, 2020, 16:44
Default SIMPLE and COUPLED Scheme for Dual Rushton Stirred vessel flow field simulation
Abhinav Hazarika
a.hazarika is on a distinguished road
Dear All Members,
I have across a case where for the same geometry ,operating conditions the flow pattern completely diverged from Parallel flow field using SIMPLE pressure-velocity coupling scheme to Merging flow field using COUPLED scheme for a dual Rushton stirred vessel . Now I am confused about which result to consider and am not able to explain as to why I am getting such a huge difference in the flow-field with change in Pressure-Velocity coupling. Experimental validation is not possible in this case.
Could you kindly provide me some insight and feedback in this regard? Looking forward to hearing from you.
Kind Regards,
Abhinav Hazarika
a.hazarika is offline   Reply With Quote
Old   February 11, 2020, 05:01
Default Either both are wrong or one is
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It is quite possible that the results from both cases are wrong and reasons could be anything from mesh, material properties, models, to numerical schemes and convergence. Usual procedure is to start checking from the top, i.e., mesh quality, however, for your case, I'd recommend start from the bottom. Check if both the cases are well converged. If the speed is on the lower side, you may have to run a transient simulation. However, if it is high enough, higher than say 5 Hz, steady-state may work.
For rotating machines, coupled is preferred scheme and should require lesser number of iterations to reach convergence, provided it reaches there. Use only higher order schemes for all fields.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Flow around cylinder using SIMPLE scheme bikooo3878 FLUENT 1 October 17, 2018 04:25
Laminar simulation with Simple Algorithms and Coupled Algorithms. lienien FLUENT 4 April 30, 2013 12:15
SIMPLE Scheme for open channel flow ao Main CFD Forum 0 April 6, 2004 17:21
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
