Max.Aspect ratio coming different in ANSYS and Fluent |
February 7, 2020, 01:26 |
SANKET BHATT
Rep Power: 6 |
Hi All,
I have complex tubular geometry, for which fluid domain has been generated in SPACECLAIM. For meshing, I have used ANSYS meshing. Max aspect ratio in ANSYS is showing 27. But once I am importing mesh to fluent, and when I am performing mesh quality check, Max aspect ratio is showing e^11. What could be the reason ? Is this compatibility issue ? Thanks. |
February 7, 2020, 03:55 |
Definition
The way AR or other metrics are defined in Fluent is different from how they are defined in ICEMCFD or Ansys Meshing. AR in Fluent is based on the ratio of farthest point of the cell from its center to the nearest point of cell from its center. If you have very stretched cells or skewed cells, AR reported could be very high. This can also happen because of left-handed faces, i.e., wrong direction of the faces. Check the mesh in Fluent Meshing before bringing into Fluent.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
aspect ratio |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 02:48 |
Fluent in Ansys Workbench : Change Working Directory | sral | FLUENT | 4 | March 29, 2019 10:29 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 17:07 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
