February 6, 2020, 00:42 |
How to overcome the udf error code
chiranjeeb jena
Dear sir/madam,
i am working on a project work ,simulation of fluidised bed ,while i am using a cfd file (conduct.c) i am getting an erroe code like (the udf library you are trying to load is not compiled for parallel use on the current platform(win64)). Please kindly help me to get the solution of this error. |
February 6, 2020, 03:28 |
Alexander
Rep Power: 34 |
run fluent in parallel (you already made it if you have this kind of error)
compile your UDF
best regards ****************************** press LIKE if this message was helpful |
February 6, 2020, 03:49 |
Compile before loading
You have to build the library before loading it. On Windows, you require either Visual Studio or Visual C++ to be installed. Start Fluent from the command prompt of the VS/VC++. Then compile it. Do note if you wish to use the code in parallel, which is default in new versions, you have to parallelize it. As of now, your code is not parallelized. To do that, use following commands within both DEFINE_ macros.
After opening braces #if !RP_HOST Before closing braces #endif
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 11, 2020, 01:36 |
chiranjeeb jena
how to download this file(conduct.c) again and where? please guide
February 11, 2020, 03:26 |
It's your file
You uploaded the file, Chiranjeeb, so, you should have it with you.
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 12:43 |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
parse error while interpreting udf | Kristin | Fluent UDF and Scheme Programming | 3 | March 15, 2012 06:43 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
