Dynamic mesh - gluing interfaces together
Old   February 5, 2020, 18:55
Default Dynamic mesh - gluing interfaces together
LHyellow is on a distinguished road
Two cylindrical elements are connected to each other via an interface.
Image:
The entirety of Element #2 has 6DOF movement, as a single rigid body. How do I make Interface #1 follow wherever Interface #2 (Interface #2 being a sub-element of Element #2) goes? Both translation & rotation.
Furthermore, how would one have interfaces follow each other, EXCEPT rotation around the axis of symmetry? If Interface #2 were to spin, I don't want Interface #1 spinning, since the opposite wall of Element #1 is anchored in place. It would twist the mesh - resulting in errors, or forcing remesh.
LHyellow is offline   Reply With Quote
Old   February 6, 2020, 06:17
Default Why interface
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If you want that fluid should flow from element 1 to 2 and their interfaces remain glued, then don't use interface. Use interior.
However, that would ensure that due to the rotation, element 1 twists, which you don't want. One way would be to apply motion to the interface 1 based on the velocity of the element 2. That would work as if it is glued. Fluent might have another option; I don't remember right now, but it has an option for the passive motion. But I suppose passive motion may not give you freedom for only translation but no rotation.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 7, 2020, 20:35
Thanks, I'll give those a look.
6dof, coupling, dynamic mesh, fluent, interface
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent Qingsong FLUENT 2 March 21, 2022 16:08
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
Sliding / Dynamic Mesh in heat transfer problem platzhalter FLUENT 0 May 7, 2018 06:25
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 09:03
