Dryer process in a Furnace simulation
Old   February 4, 2020, 13:09
Post Dryer process in a Furnace simulation
Yefferson
YefferLopez is on a distinguished road
Hi all!! I hope this message finds everyone well.
I want to simulate an industrial furnace. It consists in a rectangular chamber with a burner to supply the fuel and combustion air. The furnace is used to dry clay, which flow through the bottom of the chamber. During the process moisture is removed from the clay. Therefore, the idea is to simulate the combustion chamber but taking into acount the evaporate water from the clay.
I apreciate if you could give me ideas of how to integrate the effect of the water on the combustion process. I have thought to set the bottom wall of the chamber like a mass flow inlet of vapor water. Thanks
YefferLopez is offline   Reply With Quote
Old   February 5, 2020, 05:41
Default Reactions and Cooling
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
There are at least two ways water vapor can affect the rest of the system; it can cool the rest of the gases or it can take part in the combustion. If it is only cooling down, then it is to considered as another species in the multi-species system without involvement in any reaction. If you want to consider reaction, then you have to find out what kind of reaction it goes through and that depends on the rest of the system you have.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
cfd, combustion chamber, dry, moisture content
Transient Simulation in CFX ashtonJ CFX 1 September 28, 2018 02:18
Simulate transient heating of a slab in a furnace TMorgado Fluent UDF and Scheme Programming 0 December 6, 2012 19:41
pneumatic dryer simulation? TurbulentFluid Main CFD Forum 1 September 17, 2012 08:58
Help for simulation of De-sublimation process sohail FLUENT 0 March 27, 2008 02:51
Casting Process Simulation Anil Shenoy Main CFD Forum 1 February 22, 1999 12:56
