liquid nitrogen simulation in fluent
Old   January 24, 2020, 06:21
Default liquid nitrogen simulation in fluent
Suraj
mrmoodmechanic is on a distinguished road
problem: The rectangular tank made up of copper is filled with liquid nitrogen with the help of copper tube, there is no flow (i.e. the liquid nitrogen is completely filled )
ambient temperature = 300k
how much time the liquid nitrogen take to come at normal temperature? ( I think its a two phase simulation)
how to do the simulation in ansys?
mrmoodmechanic is offline   Reply With Quote
Old   January 29, 2020, 10:51
Default CFD may not be suitable
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
To me it does not really look like a CFD problem (or even a flow problem) until you consider that there is some kind of flow, such as because of evaporation. As long as N_2 is liquid, it has to heat up by gaining some energy. Once it reaches evaporation point, it has to gain latent heat and evaporate. Once evaporated, it begins to heat up further. Evaporation part is straightforward since heat required is given by
q1 = mL, m being mass of N_2 and L being its heat of evaporation. First and last part are easy if it is assumed that liquid and vapor are well-mixed because then it is as simple as
q2 = mC_p\Delta T
and q has to be supplied from the environment, therefore,
q1 + q2 = Ah\Delta T
It all boils down to knowing value of heat supply rate from the outside. Divide heat required by heat supply rate and you get time required. In practice, radiation plays a very important role in heating cryogenic liquids, that's why flasks are double-walled. And liquid and vapor are never well-mixed. Vapor has to be treated as ideal gas otherwise you can't contain vapor, which has a far lower density than liquid, in the same volume. If you wish to carry out CFD, you have to use VOF model with mass transfer or E-C model in Fluent.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 21, 2017 00:47
Solid Liquid Simulation FLuent sandisk FLUENT 3 November 9, 2017 02:11
Transient simulation in Fluent khaham FLUENT 13 March 15, 2016 09:18
LSR (Land speed record) car simulation on FLUENT Maxime31850 FLUENT 2 May 1, 2013 12:15
