UDS Boundary Conditions
Old   January 22, 2020, 13:19
Default UDS Boundary Conditions
Pierce
PierceH is on a distinguished road
I have a UDS that I defined using Macros, it is essentially a Poisson Solver with no inlet diffusion (mass flux off, diffusion Coefficient = 1). There are 2 velocity Inlets (bottom and left hand side) and 2 pressure outlets. The velocity inlet boundary conditions are set to an expression Static Pressure / 1[Pa] i.e the boundary of the UDS is the equivalent of the pressure solved here. The Pressure outlet is set to a 0 flux condition.
Unfortunately there appears to be significant issues in the formation of the boundaries which impact on my results. I have tried different ways to initialise and even using the UDS with inlet diffusion on but the behaviour does not perform as one would expect.
Because the Poisson solver performs as expected around the airfoil I can rule out an issue with the formation of my source term for the UDS and have narrowed this down to being a boundary problem.
PierceH is offline   Reply With Quote
Old   January 23, 2020, 00:23
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
your problem is unclear.
do you use parallel solver? take it into account,
increase iteration number
decrease under-relaxation factor for UDS
simplify model: put constant value as boundary condition (in inlet)
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
boundary condition, uds
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
CGNS Boundary conditions using SU2 denzell SU2 3 July 9, 2018 06:58
How to define the UDS boundary conditions of electromagnetic of a plasma? aestas Fluent UDF and Scheme Programming 2 March 12, 2014 03:57
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
