January 21, 2020, 15:47 |
Fluent Solution to Fluent Setup
Mairead Ryan
Hi guys,
I'm working on a blood vessel model with a lot of intricate detail I want to preserve and monitor and with the education license of Fluent having an element limit of 512,000 I've been forced to get creative around this issue. I was thinking of breaking up the model into segments and having the flow solution if each segment feed into the setup of the next fluent window (with the next geometry and respective mesh also attached to the setup window) and do this for 6 segments. Could this work and if not what would you suggest? Will upload photos later of my workbench incase a visual aid would help, as I'm presently away from my desktop. Thanks |
January 21, 2020, 16:06 |
Lucky
Rep Power: 66 |
Will it work? Yes. This is how we used to do CFD when machines had <1GB ram. Scripting helps a lot.
January 22, 2020, 05:43 |
Alexander
Rep Power: 34 |
you may try to install other version of software
best regards ****************************** press LIKE if this message was helpful |
how to use fluent species transport moudle solution mining | Feng_Xiong | FLUENT | 0 | July 17, 2019 22:34 |
Fluent Giving Different Results For Same Analysis Setup | Murwin12 | FLUENT | 0 | March 6, 2019 12:00 |
transient solution de laval nozzle fluent | ikrash | FLUENT | 0 | July 6, 2015 18:18 |
How to avoid Fluent taking a different solution path? | ansys_matt | FLUENT | 4 | August 27, 2014 12:02 |
Fluent exceeding Solution Limits on faces | bawfuls | FLUENT | 3 | July 10, 2012 17:34 |
