How to create vacuum pressure on outlet?
Old   January 20, 2020, 05:40
Default How to create vacuum pressure on outlet?
Kristjan Kragelj
kkragelj is on a distinguished road
Hello.
I have a model with 2 inlets (air, turbulent flow, 2 m/s, 360°C) and 2 outlets. How do I set the pressure on outlets - vacuum pressure of 200 Pa?
Thanks!
kkragelj is offline   Reply With Quote
Old   January 20, 2020, 13:13
Lucky
If you've already got a mesh and you're actually in Fluent, it's as simple as going to boundary conditions, selecting the outlets, setting the type as pressure outlets and specifying a pressure of -200 Pa. The real question is where are you currently at?
Old   January 22, 2020, 02:09
Kristjan Kragelj
I figured it out myself, thanks anyway!
Old   January 24, 2020, 14:31
Ran
random_ran is on a distinguished road
Does it mean that once the pressuer is below 101,325 Pa, it is then considered that the region is vacuum?
Yours in CFD,
Ran
random_ran is offline   Reply With Quote
Old   January 27, 2020, 06:40
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what is vacuum? from your point of view
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 27, 2020, 10:11
Ran
Some people say vacuum refers to any space in which the pressure is
considerably lower than atmospheric pressure.
I think that we should focus on the density not pressure.
"Whenever the density of gas in a given volume is reduced below that
corresponding to the density of atmospheric gas at ground level, a
vacuum is obtained. "
- G. F. Weston Ultrahigh Vacuum Practice.
For example, when the air flow pass a circular cylinder, there is a low
pressure area in the leeward side fo the cylinder. How can you say that
the recirculation zoon (low pressure are) is vacuum due to pressure is
lower than the other part?
Yours in CFD,
Ran
Pressure inlet vs outlet position, transient, time dependent pressure and gravity silent2608 FLUENT 0 February 6, 2016 11:19
simple model, difficult outlet Eric CFX 7 May 23, 2014 09:13
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Using pressure outlet BC Shreyansh FLUENT 0 November 5, 2010 15:57
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
