Mixing of liquid nitrogen with gaseous nitrogen in a conduit
Old   January 5, 2020, 11:00
Lightbulb Mixing of liquid nitrogen with gaseous nitrogen in a conduit
Nik
Cfdqueries is on a distinguished road
I am looking forward to perform an analysis wherein, i want a regulated temperature of gaseous nitrogen in the range of 120 to 130 K. I am planning to mix gaseous nitrogen with liquid nitrogen in a pipe.
Due to evaporation of liquid nitrogen, gaseous nitrogen will cool down.
Given some pressure inlet BC, which model is suitable for such analysis, Multispecies transport model (non-reacting) or Multiphase model (VOF or mixture).
Cfdqueries is offline   Reply With Quote
Old   January 5, 2020, 13:06
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
The conditions are near the critical point, so you first need a real EOS model. Moreover with a density based solver you have to play with large spurious velocity and pressure oscillations, when you pass the two phase region or the widdom line. Generally such simulations are performed with a HEM model, because surface tension is neglectable and the phase interface is quite diffusive.
I am no Fluent expert, so i can't suggest you a solver, but the simulations are quite challenging, especially when you have to deal with more than one component.
So good luck!
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
evaporation, mixture evaporation, multi species transport, multiphase, vof method
How to create liquid gaseous interaction in the same container? haristrawberry CFX 4 June 14, 2015 07:54
Cavitation with Nitrogen Liquid?? lehoanganh07 FLUENT 2 July 18, 2014 05:57
Is liquid Nitrogen a heat sink? vasava FLUENT 0 September 5, 2013 04:25
Liquid Nitrogen + Air Thanathat FLUENT 1 October 10, 2009 03:50
evaporation on the surface of liquid nitrogen dodo FLUENT 0 March 3, 2008 05:37
