Can't Get Temperature distribution in Solids in Fluent (Pipe cooling) |
Bobby Charlton
Rep Power: 0 ![]() |
Hello guys,
I am trying to study the cooling of air that is flowing inside a steel pipe that sits in ambient air. I have modeled the 3 different domains (air-environment domain, steel pipe domain, air flowing domain) and have created a part of all three domains. I have a great structured mesh. I have set the temperature of the air-environment at 273 K through the Fixed Values option in the Domains tab. The air is still and not moving so I have not defined any inlets/outlets. I have set the steel pipe domain as a solid. I have defined a velocity inlet (2 m/s and 320 K) and pressure outlet (0 pascals, 300 K backflow temperature) for the domain of the air flowing inside the pipe I get a wall and shadow wall for the outer surface of the pipe, which is set as Coupled. I have the same for the inner surface of the pipe. I am running the simulation and I am getting a result but when I get a temperature contour of a cross-section of the whole pipe, I get a specific temperature at the normal direction of the heat flow, instead of a classic conduction profile inside the pipe. There is no gradient of the temperature inside the steel pipe. I only get a temperature drop in the direction of the flow (axial direction) but not in the radial direction. Note that I get an expected gradient for the ambient air and the air inside the pipe. Does anybody know what's up with this? I am trying to get the temperature profile of the steel pipe without doing an FSI with Fluent and Static Thermal. I even tested a regular wall with two air domains on each side, one hot and one cold, and I still don't get a conduction profile, just a specific value of the temperature (a specific color in the contour). I have created and meshed the solid geometry of the wall. Thanks! Last edited by Bobby Charlton; January 1, 2020 at 13:54. |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
Macros for radial distribution, solids pressure and granular temperature | m.uzair | FLUENT | 0 | October 28, 2018 16:49 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Indoor Air Temperature distribution - convergence problem | Shogan | FLUENT | 4 | May 8, 2014 03:07 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
