Nozzle flow NOT expanding and following virtual pipe - physically unrealistic |
December 12, 2019, 01:04 |
Benoit
Rep Power: 6 |
I'm simulating a CD nozzle but the flow detaches at the throat and follows a 'virtual' pipe instead of expanding throughout the nozzle divergent section. Can anyone tell me what is going on?
Setup: General: pressure-based Inlet (radial): C2H4 mass flow inlet Inlet (axial): N2O mass flow inlet Outlet: static pressure =101325 Pa (1 Atm) (0 gauge pressure) Viscous turbulent flow: k-e (but any other turb. model gives the same result) Species: non-premixed combustion If I switch to density-based solver, I can't use the non-premixed combustion model... (not available in that case). |
non-premixed combustion, nozzle, pressure based solver |
