Read adaptive mesh data using Paraview
Old   December 11, 2019, 12:27
Cool Read adaptive mesh data using Paraview
CHEN
Barry_Chen is on a distinguished road
Recently, I used Fluent software to do some fluid flow modelling. When I was using adaptive mesh to do some calculations, I met some problems:
1. When I used adaptive mesh to do the calculations, the two-dimensional simulation results (XX.plt) can be opened by Paraview while the three-dimensional ones can not.
2. Is there any way to use two physical parameters (for example, temperature and velocity) to control a dynamic adaptive mesh refinement.
3. I was also using a uniform mesh to do some calculations. I found the calculation is very time-consuming. My model considered heat transfer, multi-phase flow and free surface tracing. The mesh number is around 300,000. It needs more than 5 days to finish 1 s physical-process simulation. Is that normal ?
Any useful suggestions are welcome and appreciated!
Kind regards,
Barry
Barry_Chen is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
[General] Paraview time series data with a single mesh file Artur ParaView 0 October 19, 2018 18:20
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Problem running in parralel Val OpenFOAM Running, Solving & CFD 1 June 12, 2014 03:47
How to read mesh data from ANSYS mspilot FLUENT 3 August 21, 2003 07:00
