Selection of model and calculation of Reynolds no
Old   December 9, 2019, 23:10
Exclamation Selection of model and calculation of Reynolds no
SANKET BHATT
sanket2309 is on a distinguished road
Hi everyone,
I am simulating 'Plugging' operation of complex tubular structure as shown in attachment. From figure, you can observe, the fluid domain will be very complex. In plugging operation, required boundary conditions are
1) It is steady state case in which 1500 psi pressure is applied while there will be no flow throughout the domain since flow will be chocked at the bottom portion (shown in brown color). I want to analyze net force on mandrel (green color)
1) Now, for this operation, which model should give me appropriate result, since there is no flow, how to choose model?
2) In future, suppose I want to flow fluid with boundary conditions as inlet and outlet mass flowrate (10bpm to 20 bpm) , how to calculate Reynolds no, since lot of variations diametrically, and in that case which model to chose?
Thanks.
Regards,
SANKET
sanket2309 is offline   Reply With Quote
Old   December 10, 2019, 00:42
Lucky
1) Any model works. As you noted, there is no flow. You might as well choose laminar so that there's no influence of any turbulence or wall models.
2) There's too many length scales for a single Reynolds number to make any sense. Don't even bother.
Old   December 12, 2019, 10:42
SANKET BHATT
Hi Sir,
Thanks for replying. Can you suggest me boundary condition for cementing case?. I want to analyze pressure in two different chambers. I only know mass flow (in and out - will be same). Is this correct boundary conditions?
Thanks.
model selection, plugging, reynolds number
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Standard K-Epsilon TO Reynolds Stress calculation (for convergence) wjarrah Main CFD Forum 2 May 27, 2010 06:32
Reynolds transport, turbulence model, etc Beginner Main CFD Forum 1 January 7, 2009 06:36
Reynolds stress calculation from k-epsilon model Sae woong Kil CFX 2 December 4, 2008 18:59
