how to set the vapor pressure in plain orifice atomizer injections
Old   December 8, 2019, 23:07
Post how to set the vapor pressure in plain orifice atomizer injections
Springyuu
Springyuu is on a distinguished road
the user guidline says that the vapor pressure in plain orifice atomizer injection is the vapor pressure governing the flow through the internal orifice in the Vapor Pressure field. It's not the upstream pressure nor the downstream pressure. but I can only be sure about that the upstream pressure is 0.2Mpa, the downstream pressure is 0.1MPa. So how to set the vapor pressure in the plain orifice atomizer injections? according to what? thanks a lot.
Springyuu is offline   Reply With Quote
Old   April 23, 2021, 13:57
CR
Cramsay is on a distinguished road
Obviously this is 2 years late but for anyone else who comes across this I think the vapour pressure you need to supply is the fuels vapour pressure.
Can find values for most common fuels here:
http://webserver.dmt.upm.es/~isidoro...properties.pdf
Cramsay is offline   Reply With Quote
DPM plain orifice atomizer verbosity einandr FLUENT 1 September 17, 2015 07:10
Plain Orifice Atomizer- Droplet Distribution of liquid spray Emad Ali FLUENT 0 March 21, 2015 09:09
plain orifice atomizer with heterogeneous reaction? lili FLUENT 1 May 12, 2012 08:04
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 02:40
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
