ROIN bin
Rep Power: 6 ![]() |
Recently, I was doing a large eddy simulation of a moving object, and I encountered the following error when selecting a wall model:
NOTE: The current turbulence model should only be used with the Bounded Second Order Implicit Transient Formulation. To correct this, use the '/define/models/unsteady-2nd-order-bounded?' TUI command or change the Transient Formulation setting in the 'Solution Methods' GUI Task Page. Warning: Bounded 2nd-order implicit formulation not compatible with dynamic mesh model. Switch to 1st-order implicit formulation. At the same time, the simulation of the large deformation motion in the large eddy model is of poor quality. I hope everyone can give pointers. |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Use 1st order unsteady model
6dof, les |
