Use of coal-type injection type in DPM model and define properties |
November 29, 2019, 14:43 |
greece
Rep Power: 10 |
i am using Fluent 19 to model air flow into a cylindric furnace with walls at constant temperature (approx. 900 °C). I have successfully modelled the air flow and heat transfer and now i want to study particles flow inside the field (one way coupling). Since i want to consider the case of expanding particles during heating, i want to mimic this through the swelling factor that is applicable for coal particles on DPM. The problem is that i can only select between massless and inert particle type at the Select injection properties, and "Combusting" option is not available. I have already inserted Coal as injection particle material but it is automatically named "Inert particle at the side bar and no option for changing it is given. Additionally, when i go to "Set injection properties" window and try to set manually the Laws to allow 1,4 and 5 which are applicable to Combustible particles, all of them are named "Inert heating". Does anybody know why this happen? Additionally, hoping that i will succeed to this, it is possible to personalize property values, like combustion temperature and swelling factor ? Thanks a lot in advance! Panagiotis |
coal combustion, dpm fluent |
Laminar Kinetic Energy Model (Walters 2008) | logoswort | Fluent UDF and Scheme Programming | 2 | May 19, 2017 19:41 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Udf to define new mixing law between properties of different phases in Mixture model | saurabhg2014 | Fluent UDF and Scheme Programming | 0 | February 24, 2015 03:23 |
Diesel Injection - DPM Model | Rom1 | FLUENT | 0 | March 17, 2011 10:48 |
How to define injections in DPM model | lingo | FLUENT | 5 | December 16, 2003 10:22 |
