UDF for E^n Transition Model implementation in FLUENT
Old   November 28, 2019, 10:37
Default UDF for E^n Transition Model implementation in FLUENT
Daniel Barreiro Clemente
DanielBarreiro is on a distinguished road
Good day everyone,
I´m currently working with 2D airfoil simulations at very high Reynolds numbers, and comparing the data with wind tunnel results.
So far I have been using the Transition SST model, which is the basic K-W SST turbulence model coupled with two more equations, which results in the Gamma-Theta model.
This model is by default and I haven´t changed or added anything from the initial set-up in Fluent.
However, after doing some research I have found that the K-W SST turbulence model coupled with the E^n transition model method gives better results.
The down side is that Fluent does not give this option in the turbulence model dialog box, so I assume it must be implemented through some kind of UDF in the KW SST turbulence model.
Does anyone has experience with this, or has done something similar?
Any help would be very much appreciated
Thanks in advance!
DanielBarreiro is offline   Reply With Quote
Fluent in-built models' UDF Population Balance Michaeladam FLUENT 2 June 29, 2019 06:16
standard wall function UDF fluent (k-omega model) alinik Fluent UDF and Scheme Programming 0 April 27, 2017 19:05
v2f model implementation for airfoil in FLUENT Sunil FLUENT 4 December 7, 2016 19:17
problem with UDF for (v2-f) turbulence model in fluent artemiss1984 Fluent UDF and Scheme Programming 6 January 17, 2014 06:50
Di Felice drag model FLUENT UDF Musa Fluent UDF and Scheme Programming 1 November 25, 2013 04:20
