How do I calculate power coefficient with respect to TSR of savonius VAWT ? |
November 20, 2019, 11:37 |
ahmed eissa
Rep Power: 7 |
I Am trying to simulate Savonius VAWT WITH HELICAL ROTOR OF 180 through CFD. Problem I am facing is that value of Cp or Ct is always increasing with respect to TSR and not decreasing at any point in whole range of TSR used (0.3-1.2).like experimantal data
For calculation of Cp, I am using following formula. Cp = Ct* TSR For unsteady simulation Time step size according to angular velocity of turbine were set for 360 step for a complete revolution of turbine. Simulation were carried out for 4revolution and Cm- history were stored for each time step. Last 360 time step were used to calculate average Cm (coefficient of moment). and I used this avg . Cm as Ct (torque coefficient) and calculated Cp. But Value I found for whole range is always increasing. Pls Suggest me where I am making mistake |
May 19, 2020, 18:31 |
Hüseyin Can Sülük
Rep Power: 6 |
Hello bro, i have excatly same problem with you i hope u have solved it? i have changed mesh like 10 times but still same problem i hope you could help me.
October 4, 2022, 18:17 |
Did u find a solution ?
daniel gemayel
How calculate the local heat transfer coefficient of a face? | h0rst | FLUENT | 0 | February 19, 2017 09:09 |
how to calculate time averaged skin friction coefficient | adilio | FLUENT | 2 | January 28, 2017 05:00 |
About calculate convection coefficient "h". | fluboy | FLUENT | 2 | September 14, 2009 11:57 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
