how to set the material properties if I choose the real gas model |
Springyuu
Rep Power: 6 ![]() |
The pressure in my calculation domain can change from 100Pa to 0.1Mpa,so the physical properties vary with pressure. If I choose a real gas model for the density of air, how should I set the other physical properties besides UDF ?
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Each property has its own EOS. You can use real properties for density and still use constant properties or arbitrary for everything else.
Which properties are you discussing? What would you like them set to? Why is the word UDF even being mentioned at all? |
Springyuu
Thank you. I want to set the specific capacity, viscosity and thermal conductivity as a function of pressure.
material peoperties, real gas model |
Real gas model for refrigeration compression? | Bdew8556 | Main CFD Forum | 0 | May 17, 2017 10:01 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
Continuing User Defined Real Gas Model issues | aeroman | FLUENT | 6 | April 8, 2016 03:34 |
Parallel User Defined Real Gas Model | aeroman | FLUENT | 4 | July 1, 2015 06:09 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
