How Link NIST REFPROP WITH ANSYS FLUENT USING COMMANDS TO ADD THERMAL PROPERTIES?
Old   November 17, 2019, 11:18
Post How Link NIST REFPROP WITH ANSYS FLUENT USING COMMANDS TO ADD THERMAL PROPERTIES?
ATUL S B
atulsbhat is on a distinguished road
I am Currently Working on Developing Correlations for SuperCritical Fluids for a rectangular Flat Plate. As I am New To ANSYS FLUENT , Can You Kindly Guide me How to Add, Thermophysical Properties of Supercritical Fluids (Cp, Rho, Viscosity and Thermal Conductivity), ISOBARIC 225 BAR, Varying With Respect to Temperature 630K to 670K. I do have access to To Nist REFPROP and I am Not Able to Hook it with ANSYS FLUENT.
Thank You
Atul S Bhat
atulsbhat is offline   Reply With Quote
Old   November 18, 2019, 11:51
Lucky
You don't need to hook it. REFPROP is integrated into Fluent already. To use it, type:
define/user-defined-real-gas-models/nist-real-gas-model
and then follow all the prompts
Old   November 18, 2019, 13:47
Default Cp Came Negative and Density was not Added
ATUL S B
I Tried Doing This, But Wrong values of Cp Came and Density as Function of Temperature was Not Inputted. Density Error Came
Can You Kindly Guide me How to Add, Thermophysical Properties of Supercritical Fluids{H2O} (Cp, Rho, Viscosity and Thermal Conductivity), ISOBARIC 225 BAR, Varying With Respect to Temperature 630K to 670K. I do have access to To Nist REFPROP and I am Not Able to Hook it with ANSYS FLUENT. I am not able to add a pic here where i used commands and Failed.I can Mail U, If You provide me ur mail address.
BC: Velocity Inlet and Pressure Outlet, Pressure Based Solver, Parallel processing, Laminar
Old   September 11, 2020, 10:53
Default Property Variation of Supercritical Flow
thedal's Avatar
Thamilmani M
thedal is on a distinguished road
Have you solved this problem?
I am also working with ANSYS in simulating supercritical pressure fluids.
Always
Thedal
thedal is offline   Reply With Quote
ansys fluent 19.0, ansys fluent 19.2, cfd - post, fluent - udf, properties of fluid
How to define a hole as boundary condition in Ansys Fluent using Fluent an mesh only? Nagu Sattenapalli CFD-Wiki 0 August 12, 2019 05:03
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 01:17
add a fuel cell model in ansys fluent 15 msdkhl FLUENT 0 June 15, 2016 10:14
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
