Stuart
Rep Power: 6 ![]() |
I am currently working on a ANSYS Fluent model which involves injecting sand particles into laminar water flow. I am aiming to investigate the effects of adhesion on the particle behaviour. However, I have tried the various methods of particle injection such as group, surface etc which results in the particles following a vertical downward path so there is no particle interaction. Therefore I would like to know if there is a way of injection the particles with random velocities in the x,y,z direction to promote particle-particle interactions. I am aware this may be possible by creating an injection file using MATLAB but I have no MATLAB experience so I'm wondering if there is a simpler method. Thank You |
discrete, dpm, fluent, injection, particle |
UDF for particle injection using file | shahjehan | Fluent UDF and Scheme Programming | 2 | June 28, 2020 10:44 |
file injection.: continuity fail; volume injection.: wrong total mass | blerli_91 | Fluent Multiphase | 6 | October 2, 2018 05:34 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
particles leave domain | Steffen595 | CFX | 9 | March 7, 2016 16:19 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
