Fluent initialization UDF
Old   October 28, 2019, 19:52
Default Fluent initialization UDF
Amir
ALBATTROSS is on a distinguished road
Hello all,
I'm initializing the flow with a UDF in FLUENT with the following UDF:
DEFINE_INIT(pure_cond, domain)
cell_t c;
Thread *t;
real xc[ND_ND];
/* loop over all cell threads in the domain */
thread_loop_c (t,domain)
/* loop over all cells */
begin_c_loop_all (c,t)
C_T(c,t) = -5000*xc[0] +100 ;
end_c_loop_all (c,t)
the problem is: Because this udf only specifies the values at the centroid The boundaries (i.e. The values of Temperature at boundary nodes) are not taking the values of this initialization. Surprisingly the values on the temperature at boundary nodes are not the same as the boundary condition values. I want specified values on boundaries when I initialize. Do you suggest a solution to this?
I attached a picture of the domain below
Thank you
ALBATTROSS is offline   Reply With Quote
Old   October 28, 2019, 23:58
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
make a loop over faces.
switch of "node values" option, when you plot contours
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 1, 2023, 14:16
Taosif Alam
taosifme014 is on a distinguished road
Hi, Are you able to fix this?
taosifme014 is offline   Reply With Quote
Problem running fluent with udf on batch tobi b. Fluent UDF and Scheme Programming 3 April 14, 2016 14:54
UDF for temperature initialization in FLUENT Ami24 FLUENT 0 February 25, 2016 09:27
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 11:16
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 11:57
