shear stress on a wall
Old   October 26, 2019, 06:58
Post shear stress on a wall
arash
Araash is on a distinguished road
hello everyone,
i have a simple 2D problem (i attach a picture of the problem).
left side is velocity-inlet and the right side is pressure-outlet. circle has a constant temperature and the fluid is only water. i want to add hydrophobic boundary condition to the wall(circle) then compare the shear stress on it with the hydrophilic one.
how can i add this boundary condition in fluent?? pls help.
Araash is offline   Reply With Quote
Old   October 26, 2019, 07:32
jens meier
force_95 is on a distinguished road
Originally Posted by Araash View Post
hello everyone,
I guess you have to solve this problem with the help of a User defunded function (UDF)
force_95 is offline   Reply With Quote
Old   October 26, 2019, 13:17
Lucky
You need to translate "hydrophobic" into a physical parameter that can be modeled.
Usually this means setting the wettability using the contact angle from a multiphase model.
Old   October 26, 2019, 13:37
arash
thank you @LuckyTran for your reply.
yes I need to change the contact angle between water and wall.
in the multiphase model we have 2 phases: primary phase and secondary phase and that means we should have 2 fluids.
but in my problem, I only have one fluid and that is water.
is there a way that I can change the contact angle between water and wall?
I really need help...
Old   October 26, 2019, 13:40
Post
arash
Old   October 27, 2019, 15:54
Lucky
A hydrophobic phase exists only when there is also an immiscible hydrophilic phase. There is no "contact angle" when you only have water.
Old   October 27, 2019, 16:36
arash
thank you for your answer,
if I put air and water in this problem...what should be the volume fractions?? for example if I give 0.7 for water would it be ok??
I have another question and i really appreciate it if you answer...
can I put this hydrophobic boundary condition with slip boundary condition on the wall?
fluent
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Zero Wall shear stress at porous interface ftab CFX 0 January 18, 2017 11:53
Wall Shear Stress Sampling Probes Mahe88 OpenFOAM Post-Processing 0 December 14, 2016 11:09
Wall Shear Stress prediction varies with fix y+ Jeeloong FLUENT 0 November 24, 2016 18:17
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 15:41
