Simple setup with mass inlet en pressure outlet but no convergence
Old   October 24, 2019, 03:57
Default Simple setup with mass inlet en pressure outlet but no convergence
Benoit
Benoit85 is on a distinguished road
Hello everybody. I'm new to CFD. Please find screenshots in attachment to clarify my case.
I'm trying to run a simple axisymmetric flow case: 2 mass flow inlets (air), 1 pressure outlet, 1 axis, and some walls. Fluid: all air. Flow: inviscid. Solver: density based. In the future, I want to add and change some elements of the case, but for now I wanted to start simple. Apparrently I'm already doing something wrong.
The problem: at first, the solution seems to converge, but it happens very slowly (the total mass outflow approaches the sum of both mass inflows), but in the end it diverges.
When I choose pressure inlets instead of the mass flow inlets, the solution converges very quickly without any problem. Why is it so different with mass flow inlets? I need mass flow inlet BC because of the nature of the problem I want to simulate later on.
What am I doing wrong? Thanks!
Benoit85 is offline   Reply With Quote
Old   October 24, 2019, 04:55
Arnie
arnie333 is on a distinguished road
Hi Benoit85,
Are you sure that the inlet BCs you have modeled are realistic/representative of actual equipment/system ?
It looks to me like you will get significant reverse flow at the inlets and a very unstable system/analysis.
arnie333 is offline   Reply With Quote
Old   October 24, 2019, 05:15
Benoit
Originally Posted by arnie333 View Post
Hi Benoit85,
Thanks for your reply. For now, I'm using only air, but the system will be N2O inlet (the mass flow is known through experiments) and burning fuel grain (modeled as vaporized C2H4) of which the burning rate (and thus mass flow) is also known via experiments. That's why I want to impose a mass flow rate.
I just ran another simulation with Standard k-eps turbulence model and you can see the results in attachment. It converges way too slow, and actually, it still isn't really converged (see corner at outlet).
air flow inviscid flow, convergence failure, mass flow inlet, nozzle, pressure outlet
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep pvpnrao OpenFOAM Running, Solving & CFD 2 September 11, 2018 11:14
Pressure Boundary Inlet and Outlet AS_Aero CFX 5 March 28, 2018 11:46
Setting both inlet and outlet with pressure boundary conditions ahmadbakri CFX 0 July 1, 2015 05:06
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
