Fluent - Center of pressure
Old   October 15, 2019, 11:21
Default Fluent - Center of pressure
Oleh Tkachuk
oleh-tkachuk is on a distinguished road
I am trying to obtain a center of pressure of an axisymmetric body using ANSYS Fluent. It is a cylinder at 10m/s where the body is aligned with the flow (x direction). The origin is located on the symmetry axis on the surface of the cylinder (closer to the inlet).
I cannot understand why the results of center of pressure fixing y-axis (y=0) or z-axis (z=0) are different, moreover one of the results (fixing z=0) is outside of the body. Apparently the results of both cases should be the same, considering that the body is axisymmetric.
Best regards
Oleh
oleh-tkachuk is offline   Reply With Quote
axisymmetric body, center of pressure, fluent
Fluent cyclone pressure drop mkal FLUENT 1 February 20, 2020 01:55
Fluent Center of Pressure Report Generation kdwoell FLUENT 1 January 18, 2011 13:29
Center of pressure and FLUENT, please help Bridou FLUENT 5 July 4, 2007 10:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
