Solar concentrator radiation problem (solar ray tracing) |
October 14, 2019, 17:41 |
Abhinay
Rep Power: 11 |
I am trying to determine the solar heat flux distribution on a cylindrical receiver that is reflected from a dish type concentrator. I did not find any tutorial that involves solar concentrators! I want to simulate simple case without any fluid involved. Just a dish concentrator (mirror) and solid cylinder located at the focal point. There is no air or any other fluid medium. Can I use S2S model with solar ray tracing for this case? I tried to create a view factor file, but it shows an error " The number of radiating faces should be a non-zero. Atleast one boundary zone (attached to the fluid) should participate in the view factor computation" Is it necessary to have atleast one fluid component to use S2S? I don't get this error if at least one of the components is defined as fluid. If S2S is not appropriate for this case, which radiation model is good for solar concentrators. Thanks! |
October 14, 2019, 17:59 |
Lucky
Rep Power: 66 |
You need a fluid. If you're planing on doing only a radiation model, you still need a dummy non-participating fluid. The radiation models in Fluent are not meant to be standalone radiation solvers. What Fluent is looking for is the boundary zone attached to the working fluid to perform the view factor calculation.
October 16, 2019, 01:43 |
Abhinay
Rep Power: 11 |
Sorry for the late response. Thank you very much for the clarification! I will try model it with some dummy fluid in my model and see if it works. Thanks again for the response.
fluent, radiation, ray tracing, s2s, solar concentrator |
solar calculator problem | yosr | FLUENT | 1 | October 31, 2011 05:50 |
A problem with solar still modeling | Amir Khodabandeh | FLUENT | 2 | April 3, 2011 22:55 |
[ICEM] Solar Water Heater Mesh Problem. | OzMantle | ANSYS Meshing & Geometry | 17 | July 27, 2010 20:14 |
solar ray tracing | yosr | FLUENT | 0 | January 29, 2009 11:40 |
solar radiation problem | Cha | Siemens | 0 | June 13, 2004 17:11 |
