October 10, 2019, 14:29 |
Meshing of a serrated trailing edged wing
Rohith Sai Pasupuleti
Can someone here help me in meshing the serrated trailing edged wing? I am facing a problem during creating face meshing. The problem was that the material was cut in order to get the serrated edges. Now, it had created the problem that, while doing the boolean ony the normal sharp trailing edge was cut but the material remained as such. so, the boolean wasn't appropriate. I am attaching the screenshot of my project. If someone is interested, please help me.Even if there is any reference video, please kindly share it here. |
October 26, 2020, 16:00 |
Rep Power: 9 |
Hello, I'm facing a very similar problem. Can you tell me how you solved it?
Thanks |
mesh 3d, meshing problem, trailing edge morphing, workbench |
Structured Meshing of Wing Surface | Naruto | Pointwise & Gridgen | 6 | September 28, 2017 12:34 |
[ANSYS Meshing] 3D wing blocking and meshing | marcanyada | ANSYS Meshing & Geometry | 0 | September 3, 2014 13:57 |
[ICEM] Trailing edge meshing problems | juanchope | ANSYS Meshing & Geometry | 2 | June 19, 2014 22:10 |
[ICEM] Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh | yona | ANSYS Meshing & Geometry | 8 | January 21, 2014 11:06 |
Meshing a 3D wing | Prakash.Paudel | ANSYS Meshing & Geometry | 1 | July 26, 2011 19:26 |
