Dumb Ansys Fluent can't compile UDF
Old   October 8, 2019, 16:26
Default Dumb Ansys Fluent can't compile UDF
Emre
ordinary is on a distinguished road
Hello everyone,
I try to compile a UDF for a 2D case. Unfortunately I encounter a warning which says
Error at host: Error code: 193
Error at Node 0: Error code: 193
My Fluent is Version 19.4.0 for ANSYS 2019 R2.
As far as I know I have to run Ansys via Cross Tools Command Prompt. Thus I installed Visual Studio Community 2019 and Desktop Development for C++.
I run x64_x86 Cross Tools Command Prompt for 2019 as admin. Then I type
C:\Program Files\ANSYS Inc\ANSYS Student\v194\Framework\bin\Win64>RunWB2.exe
This is the Fluent terminal output after building UDF:
> Copied C:\Users osh\Desktop\linearmotion\linear.c to libudf\src
** WARNING: Automatically switched to run in parallel -t1 mode. **
** Detected non-parallelized UDF usage, enabling parallel usage. **
** If you encounter any issues, please re-run with -t0 flag. **
************************************************** **************************Creating user_nt.udf file for 2ddp_host ...
(system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v194\fluent"\fluent 19.4.0\src\udf\makefile_nt.udf "libudf\win64\2ddp_host\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_host")# Generating ud_io1.h
linear.c
# Generating udf_names.c because of makefile linear.obj
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj linear.obj
Microsoft (R) Incremental Linker Version 14.23.28105.4
Copyright (C) Microsoft Corporation. All rights reserved.
Creating library libudf.lib and object libudf.exp
***Creating user_nt.udf file for 2ddp_node ...
(system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v194\fluent"\fluent 19.4.0\src\udf\makefile_nt.udf "libudf\win64\2ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_node")# Generating ud_io1.h
linear.c
udf_names.c
Done.
And finally this is what I get after I push the Load button:
DESKTOP-Q4P9KJI: Opening library "C:\Users\tosh\Desktop\linearmotion\motion_files\d p0\FLU\Fluent\libudf"...
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: Error code: 193\n
Error Object: #f
I tried to add environmental variables according to https://sites.psu.edu/zfzhang/notes/...f-environment/.
I added these lines to the Path in User Variables:
C:\Program Files\ANSYS Inc\ANSYS Student\v194\fluent
C:\Program Files\ANSYS Inc\ANSYS Student\v194\fluent\ntbin\win64\fluent.exe
Also these for User Variables
INCLUDE
C:\Program Files\Microsoft SDKs\Windows\v7.1\Include
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.23.28105\in clude
LIB
C:\Program Files\Microsoft SDKs\Windows\v7.1\Lib\x64
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.23.28105\li b\x64
Do you have any idea?
Regards,
ordinary is offline   Reply With Quote
Old   October 9, 2019, 08:55
sufjanst is on a distinguished road
I also had problems with Visual Studio 2019. I tried Visual Studio 2015 Express and it worked.
sufjanst is offline   Reply With Quote
udf
UDF velocity inlet. Different values (compile - Fluent) asking FLUENT 0 July 13, 2018 18:02
UDF Defining in ANSYS FLUENT 16.2 in Win 10 Sadegh.A Fluent UDF and Scheme Programming 11 February 15, 2017 15:45
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Fluent 6.3.26 on Linux does not compile an UDF Entwistle Fluent UDF and Scheme Programming 1 March 4, 2014 15:49
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
