October 6, 2019, 16:55 |
HELP: Transient Simulation on a Cluster
M.Eid
Rep Power: 8 |
I am running a fluent transient simulation on a Cluster. After some time steps fluent stops at the "Updating solution at time levels N and N-1 Done" All nodes are still 100% running yet the next time step won't be solved. I have no idea if it is a fluent problem or from the cluster and i waited 1 full day. If anyone might have a solution/suggestion please let me know asap. Thanks! |
October 7, 2019, 16:35 |
Lucky
Rep Power: 66 |
Fluent is done. If you check your cpu load, it's probably 0%.
Check your settings and figure why it's not doing more time-steps. My guess, you have some convergence criteria set that's telling Fluent "it's done" |
October 7, 2019, 17:34 |
M.Eid
Rep Power: 8 |
I set time step number to 100000 but it only does 1 or 2 and stops.
The cpu loads are still at 100%. The same case works fine on any single machine but the problem seems to be occurring on a cluster only |
October 7, 2019, 20:38 |
Svetlana Tkachenko
Rep Power: 15 |
What fluent version are you using? Can you please consider running another simulation on the cluster, something simpler like flow past a cylinder. Does it work correctly or not.
October 8, 2019, 04:16 |
M.Eid
Rep Power: 8 |
I tried versions 17.2, 19R1, 19R3
I ran a simpler flow over a cylinder and it works fine |
October 8, 2019, 05:04 |
Svetlana Tkachenko
Rep Power: 15 |
What are the differences between the two simulations. Try increasing complexity, set it to transient, add any other missing physics or setup.
At the same time try to decrease complexity of your original model: make it laminar model, isothermal, etc as simple as you can even if this makes no sense for the physics. Does this come up with anything meaningful? If this is not a big or confidential problem, upload your fluent .cas file and I can give it a try. |
October 8, 2019, 11:21 |
Lucky
Rep Power: 66 |
Run out of ram?
October 8, 2019, 11:29 |
M.Eid
Rep Power: 8 |
No there's plenty of RAM left
How to stop transient simulation which has been run from scheme script? | AlexanderZ | FLUENT | 8 | August 31, 2017 05:25 |
Transient RANS Simulation | Bazinga | Main CFD Forum | 5 | June 21, 2017 12:21 |
the problem of my transient simulation "Floating point exception: Overflow " | alloveyou | CFX | 15 | November 22, 2012 12:14 |
Beginning a Transient Simulation | Norflow | CFX | 2 | October 7, 2011 01:38 |
Resume Transient simulation | HMR | CFX | 1 | June 28, 2011 22:13 |
