Adding fans that improve air circulation into rooms without adding an inlet T
Old   October 6, 2019, 13:18
Default Adding fans that improve air circulation into rooms without adding an inlet T
Bran is on a distinguished road
I am working on a problem where I have a room with an airconditioner and various heat sources. I applied a volumetric heat generation term to the heat source and have an inlet velocity from the air conditioner at 273 K for cooling.
I want to add a few additional fans into the room that function to improve the cooling in the room.
When I set the inlet velocity of the additional fans, it is set at 300K which I believe messes up the air conditioner cooling of the room and components.
How do I make these fans just add circulation into the room?
Bran is offline   Reply With Quote
Old   October 10, 2019, 11:33
Lucky
What you want is not a boundary condition but a momentum source
Old   October 10, 2019, 11:35
Thank you for your response. I was wondering how I can specify this momentum source into Fluent in order to simulate a fan.
Pressure & Air circulation noppawit FLUENT 0 October 16, 2010 11:38
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 19:42
Inlet air preheating usker Siemens 3 September 21, 2006 09:21
Increasing air flow using fans jim sanders FLUENT 0 January 10, 2002 10:24
