Problem setup and Boundary conditions for a heat exchanger using supercritical CO2
Old   October 5, 2019, 18:41
Default Problem setup and Boundary conditions for a heat exchanger using supercritical CO2
Akshay
orange20 is on a distinguished road
Hi all,
I have been trying to simulate flow through a unit cell of a shell and tube heat exchanger using supercritical CO2 as the working fluid for both the internal (tube) flow and external (shell) flow. I am having trouble obtaining a solution to the problem. I have used the NIST real gas database and I have tried simulating as an incompressible flow as well for simplicity but I cannot seem to converge my solution. I have uploaded a figure of my mesh and the details for my simulation are as follows:
The black arrows in the figure depict external flow inlet and outlet.
The red arrows depict internal flow.
Maximum skewness of the mesh in 0.89.
The mass flow rate throughout the cycle is constant as the heat exchanger is part of a closed loop.
Turbulent flow: Assuming the k-omega SST model
Pressure-based solver
NIST real gas model for supercritical CO2
At tube inlet:
Mass flow rate for each tube (Constant from inlet to outlet) : 0.00184 kg/s
Pressure inlet : 250 bar
Temperature at the inlet : 300 Celsius
At the shell inlet:
Mass flow rate (Constant from inlet to outlet) : 0.1032 kg/s
Pressure inlet : 80 bar
Temperature at the inlet : 800 Celsius
I have been at it for a while now, trying different possibilities but I feel like I am missing something basic. Could any of you be kind enough to help me out with obtaining the solution to this problem?
orange20 is offline   Reply With Quote
compressible flow, heat exchanger, s-co2, supercritical flow
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
How to setup periodic boundary conditions in solid-solid heat transfer liangLOL FLUENT 1 July 20, 2018 04:58
CFX Spray Breakup Setup Spray_Ansys CFX 28 June 9, 2018 08:37
Euler unsteady with moving boundary conditions - problem setup rocco.bom SU2 0 January 24, 2017 10:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
