Supersonic Flow Over Flat Plate using Ansys-Fluent |
October 4, 2019, 02:04 |
Venkata Raghavendra Nandagiri
Hello, has anyone successfully simulated Anderson Ch.10 test case of Supersonic flow over flat plate, using Ansys-Fluent? If so, please let me know what to take for:
1) The plate geometry/dimensions and the mesh dimensions 2) Boundary conditions 3) Flow solver (convective flux, etc) 4) Time step 5) Any other important info related to the Fluent simulation Please confirm if the results of surface pressure distribution as a function of distance from the leading edge obtained using Ansys-Fluent, match those given in Anderson book. |
Flow over a heated flat plate: non-physical solution | Sushobhan | OpenFOAM Running, Solving & CFD | 0 | May 4, 2018 23:43 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Supersonic flow over flate plate | SAz_ID | FLUENT | 9 | August 17, 2014 14:09 |
Question about Laminar flow over flat plate in FLUENT | gaoyitong | FLUENT | 0 | November 26, 2012 22:51 |
problem in turbulent flow over flat plate with stagnation point | mb.pejvak | Main CFD Forum | 0 | September 12, 2012 21:25 |
