Does viscous force include force of particles ? |
October 2, 2019, 04:14 |
jens meier
Rep Power: 7 |
Hey all,
I'm simulating two bubbles moving against each other. The udf code I'm using is calculating the viscous force that acts on one bubble. Because of this viscous force the bubble slows down. When I insert particles, there is absolutely no effect on the behaviour of the bubble ( like slow down very faster). Do I have write another UDF with DPM_Drag _force in order to calculate that particle force ? Kind regards |
Adding a new force to lagrangian particles | Kabra | OpenFOAM Programming & Development | 3 | July 8, 2021 13:34 |
viscous Force in UDF-File | force_95 | FLUENT | 0 | September 26, 2019 05:16 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 11:42 |
Lagragian particles get the right force but wrong velocity | Kabra | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 11:27 |
to separate pressure force and viscous force using udf | ignayars | Fluent UDF and Scheme Programming | 1 | October 19, 2014 08:26 |
