Why do a residual/residuals start from a big non-zero magnitude sometimes?
Old   September 30, 2019, 08:38
Default Why do a residual/residuals start from a big non-zero magnitude sometimes?
Roh
Roh is on a distinguished road
Guys,
Sometimes after initializing the problem in Fluent and triggering the calculate button, a residual/residuals start from a big non-zero magnitude. For instance, to me, it in many cases happens for some covection-deffusion equation when I'm simulating combustion. Interesting point is that the results looks ok and have good agreement with experimental results. In this page:
Judging Convergence
It's said that:
For most problems, the default convergence criterion in ANSYS FLUENT is sufficient. This criterion requires that the scaled residuals defined by Equation 26.13-4 or 26.13-9 decrease to for all equations except the energy and P-1 equations, for which the criterion is .
As it is said, the residuals need DECREASE TO 10^-3. Then it means that it doesn't matter from where the residual starts, it should finally decrease to 10^-3. Am I right? What's your opinion?
Another question:
Why does it happans? (I mean why does the residual start from a non-zero magnitude?)
I've attached a screenshot of the residual of a project for instance.
Roh is offline   Reply With Quote
Old   October 1, 2019, 08:21
Question
Roh
Another interesting case is attached. What's wrong with this solution?
Magnitude of a tensor mmkr825 OpenFOAM Programming & Development 9 October 23, 2024 00:41
gradient of strain rate magnitude for slip velocity totopo FLUENT 0 September 27, 2018 21:07
'cell relative: velocity magnitude' vs 'velocity magnitude' alpharays Main CFD Forum 2 June 18, 2015 08:24
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 11:31
Start star ccm+ remotely with mpiexec Dagnir Siemens 0 November 24, 2010 13:33
