Pressure drop and temperature issue
Old   September 20, 2019, 17:38
Default Pressure drop and temperature issue
msnadeem's Avatar
MS Nadeem
msnadeem is on a distinguished road
Dear connections,
I did flow analysis of cutting tool, please find attached images. the fluid(water) is coming from inlet and passing through channels and at cutting edge absorb heat and move through outlet. My question is why the temperature of fluid is decreasing till it reaches the outlet ???
To my knowledge, the fluid after passing near from the cutting edge should not decrease in temperature, if it decrease then it cannot decrease so much to get turned into cool water. Also, the outlet pressure results are decreasing near outlet, what could be the reason ? Because of this, I am unable to calculate proper pressure drop results, since the fluid velocity is totally reduced to the lowest value ???
Any solution for this ? It will be a great help.
Regards
Nadeem
msnadeem is offline   Reply With Quote
Old   September 23, 2019, 05:55
msnadeem's Avatar
MS Nadeem
Dear connections,
Can anyone at least give your reviews and reply me regarding the model ?
Kind regards
Old   September 24, 2019, 02:55
Roh
Roh is on a distinguished road
More probably your boundary conditions!
If you don't know or not sure that what should be the temp./pre./vel. at the outlet then you need to lengthen the domain to reach the location that you know the parameters at that location.
Roh is offline   Reply With Quote
Old   September 24, 2019, 03:02
msnadeem's Avatar
MS Nadeem
Dear roh,
How can I lengthen the domain ?? Can u little bit elaborate more ?
Thanks!!
Kind regards
cutting tool, fluent, fluid flow, pressure drop, temperature contours
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
pressure drop and two phase problem omaralyahia CFX 1 July 16, 2015 19:01
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
Pressure Drop Calculation mk_mard STAR-CCM+ 3 August 29, 2011 03:06
