Identifying cells having Turbulent viscosity limited to viscosity ratio of 1.000e+05
Old   September 20, 2019, 05:49
Default Identifying cells having Turbulent viscosity limited to viscosity ratio of 1.000e+05
SAYANTAN BISWAS
Sayantan Biswas is on a distinguished road
Hello Everyone,
I am solving two phaseflow (Primary phase water, secondary phase is air) on Euler-Euler frame work, K-eph per-phase turbulent model with standard Wall function.
Solution is diverging because of turbulent viscosity limited to viscosity ratio of 1.00e+5 in millions of cells.
I have saved data just before the divergences. I want to know how do I identify those million cells having 'turbulent viscosity limited to viscosity ratio of 1.00e+5'.
In CFD post processing there are two variable is available, 'Air eddy viscosity ratio' and 'Water eddy viscoty ratio'.
When I am ploting Iso Surface or Iso Volume of any of the above mention, there is no region/cells having 10e+5 order of Air/Water eddy viscosity ratio, rather max of 9000 value for Water eddy viscosity & max of 5000 value for Air eddy viscosity.
How do I identify those cells?
Sayantan Biswas is offline   Reply With Quote
3D CFD simulation of propeller blade - Turbulent viscosity limited to viscosity ratio Quentin_C FLUENT 1 April 4, 2017 06:32
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 07:15
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 12:04
turbulent viscosity limited to viscosity ratio of 1.000000e+05 syler3321 FLUENT 4 March 16, 2012 17:00
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 01:05
