Fluent convergence issues 2D airfoil
Old   September 18, 2019, 00:44
Smile Fluent convergence issues 2D airfoil
Ferruccio Rossi
frossi is on a distinguished road
Hi all,
I am working on my thesis and I am starting by simulating flow over a 2D airfoil NACA 0012 in FLUENT. I can't get my simulation to converge properly (or at least, in my opinion it is not converging properly).
In MESHING, I am using a structured mesh with 233,000 elements (see pics). I tried to get the elements to become finer as they get closer to the airfoil through element biasing.
In FLUENT, I am using the following parameters:
- Pressure based solver
- Laminar model (since my airfoil chord is 25 cm and thus low Re)
- Air with constant density
- Velocity Inlet BC (20 m/s)
- 0 angle of attack
- Pressure outlet for the rest of the domain (top, bottom, and back).
I am not understanding why my plots look so off. The residuals are oscillating greatly and are not converging. On the other hand, the mass flow and drag plots seem to be mostly steady, except for a spike which is completely out of the expected range, which makes me think that these plots are not reliable.
Also, I am getting reversed flow on one of the faces of the pressure outlet (not sure if this impacts the results or not).
Do you guys know what I might be doing wrong? I think all my selections make sense and I don't understand what I might be doing wrong.
Note: I also tried an unstructured mesh with quads and inflation layers, but I still got similarly strange plots...
Any help is greatly appreciated!
Thank you guys
frossi is offline   Reply With Quote
convergence, fluent, mesh, plot, residuals
Fluent vs. xFoil result for E423 airfoil: Cd is way off klu FLUENT 1 September 23, 2023 00:56
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
convergence issues in gas-solid flow simulation in Fluent SKS13 Fluent Multiphase 1 November 11, 2018 17:42
Fluent analysis for an airfoil pratikvn FLUENT 2 October 7, 2014 14:15
fluent convergence problem josip76 FLUENT 0 May 26, 2011 21:08
