problem with convergence in combustion model ? |
September 14, 2019, 11:20 |
Rep Power: 9 |
i am working on a steady state methane-combustion problem solved using 1.Energy eq, 2. k-epsilon 3.species transport ( Eddy Dissipation Model) 4. radiation- Discrete ordinate model. The model works fine and the entire system temperature wrt to iteration became constant after 16000 iteration as shown in figure 1 which symbolizes convergence. My geometry is too complicated......as shown below as meshed geometry...........so i dnt think i will ever be able to reduce my residuals beyond 10e-3 as the problem is too complicated.
Now the interesting thing, i changed my fuel to some other with different methane composition, the temperature is not converging as before, infact cyclic repeating temperature vs iteration profile is being obtained what should i do regarding this. I have attached the figure of temperature vs iteration as well as its corresponding residual pic as well. How can i rectify this problem and being a steady state problem at least temp need to be stabilized? will refining the mesh further solve this problem |
problem in the ECFM combustion model | Georges Thomas | CONVERGE | 1 | August 7, 2017 17:00 |
Cavity Flow Model Convergence Problem | benderbending | CFX | 2 | February 20, 2017 05:43 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 06:24 |
convergence problem with FLUENT cavitation model | Belete Kiflie | FLUENT | 3 | February 20, 2006 11:16 |
