September 9, 2019, 05:07 |
BOUNDARY_HEAT_FLUX(f,t) command
Spyros
Rep Power: 7 |
Hello everyone. I need some help about the BOUNDARY_HEAT_FLUX(f,t) command. I have found conflicting info about what exactly this function returns..
a) returns boundary heat flux in W/m2 for a given face? b) returns boundary heat flux in W for a given face? UDF - Boundary Heat Flux- c) returns boundary heat flux in (W/m2)/m2 , total heat flux for a given face in flux per area? (so that I have to multiply with the face area in order to have W/m2). 4th post in the following discussion. Total Heat Flux Calculated by FLUENT Which one is correct? or none is true and it's something else? Thank you for your time and help! |
boundary heat flux, fluent, heat flux, udf |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
