Flutter Study of a Wing with FSI
Old   September 4, 2019, 14:05
Default Flutter Study of a Wing with FSI
Simon95
escasy_95@hotmail.com is on a distinguished road
I am working on a project based on the flutter condition of a wing. To do it, I am trying to do a 2 way FSI study with ANSYS-FLUENT. I have already built the wing and done the modal study and the results are quite good. However, I am facing some problems. In my case, the study is at Mach 0.9. The information I have found suggest to modify the static pressure and realize in which case the damping coefficient is zero.
-Which solver is the most accurate one for a transonic flow?
-In fluent, I have defined a velocity inlet and pressure outlet, but I dont know if this is correct in this situation.
-In which part of the fluent configuration should I put the velocity?
-How can I display the damping coefficient in ANSYS_FLUENT, so I can see the flutter condition?
Thank you in advance.
escasy_95@hotmail.com is offline   Reply With Quote
damping coefficient, flutter, fsi, transonic flow, velocity and pressure
Flutter Study of a Wing with FSI escasy_95@hotmail.com FLUENT 2 January 1, 2023 04:57
MODAL Validation in FSI study on AGARD 445.6 wing zeeshan khan ANSYS 2 October 4, 2022 13:24
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
Wing FSI simulation: Shell elements or 3D solid body? frossi CFX 3 June 15, 2016 21:02
2-way FSI of a wing john881129 CFX 11 January 12, 2012 05:33
