September 3, 2019, 05:58 |
Pass variable from one udf to another
Spyros
Rep Power: 7 |
Hello everyone! I have created a UDF that calculates the velocity (variable name vel) from a heat transfer function. I need to pass this variable (vel) which changes value every time step to another UDF in order to link that UDF with the movement of a interface.
Is there any way I can make this? I know that with UDM one can store a value to a memory slot but dont know if I can retrieve it and use it in another UDF. Any help would be much appreciated! |
September 3, 2019, 07:24 |
Mattia
Rep Power: 8 |
HI, would'nt be possible to create just one UDF instead of two?
September 3, 2019, 09:16 |
Spyros
Rep Power: 7 |
I dont think so.. Look at the codes that I am attaching. In the first one both interfaces move with the same speed. But in the second code only one interface moves and not the other. IDK if it is some kind of mistake I do when writing the code. I need to calculate from some heat function the vel[1] for the one thread (one side of the interface) and then make the other thread (other side of that interface) move with the same vel[1] but in opposite direction so that the 2 are always connected.
Thanks in advance. CODE1 /* moving grid */ #include "udf.h" DEFINE_CG_MOTION(interf_move, dt, vel, omega, time, dtime) { int tid; double velocity; face_t face; Thread *thread = DT_THREAD (dt); tid = THREAD_ID (thread); if (THREAD_ID (thread) == 9) { velocity=-0.4*(time/10); } if (THREAD_ID (thread) == 10) { velocity=-0.4*(time/10); } vel[1]=velocity; } CODE2 #include "udf.h" DEFINE_CG_MOTION(interf_move, dt, vel, omega, time, dtime) { int tid; double velocity; face_t face; Thread *thread = DT_THREAD (dt); tid = THREAD_ID (thread); if (THREAD_ID (thread) == 9) { velocity=-0.4*(time/10); } if (THREAD_ID (thread) == 10) { velocity=-velocity; } vel[1]=velocity; } |
September 3, 2019, 16:49 |
Lucky
Rep Power: 66 |
I can't follow the logic of what you are trying to do to tell you how to do it (sorry I just can't make sense out of it).
You can certainly have more than one DEFINE macro in a single UDF. You can also access a UDM using the C_UDMI(c,t,0) or F_UDMI(f,t,0) macros (where the 0 is the 0th or first UDM). |
September 4, 2019, 01:50 |
Alexander
Rep Power: 34 |
as LuckyTran mentioned
/* moving grid */ #include "udf.h" DEFINE_CG_MOTION(interf_move_1, dt, vel, omega, time, dtime) { double velocity; {...} vel[1]=velocity; } DEFINE_CG_MOTION(interf_move_2, dt, vel, omega, time, dtime) { double velocity; {...} vel[1]=-velocity; // negative, because you want to move OPPOSITE direction } |
September 4, 2019, 09:43 |
Spyros
Rep Power: 7 |
Let me elaborate on my problem
I have a fluid domain and a solid body and the interface between them is coupled, from a heat transfer function [velocity=f(boundary_heat_flux)] ,I calculate the velocity with which the solid side interface should move and need to move the fluid side of the interface with the same velocity so that they always remain in contact. I understand that I don't need to have 2 separate UDFs and I also found out that since the interface would move down (negative Y axis) the whole sign convention doesn't need to be taken into account, both sides must move with negative velocity with respect to the global coordinate system. So the variable velocity should be calculated only in the first DEFINE_CG_MOTION (interf_move1, ..) and then passed to the second DEFINE_CG_MOTION (interf_move2, ..) in order to move the latter with the same velocity. I think this is the best way to explain it. I've tried the code provided by AlexanderZ but fluent warms me that the variable vel[1] is not used in the second DEFINE MACRO and as unticipated one side of the interface is not moving |
September 4, 2019, 22:40 |
Alexander
Rep Power: 34 |
wall between fluid and solid has coupled boundary condition, does it really needed to move both of them separately?
regarding your request Code:
/* moving grid */ #include "udf.h" double velocity; DEFINE_CG_MOTION(interf_move_1, dt, vel, omega, time, dtime) { {...} vel[1]=velocity; } DEFINE_CG_MOTION(interf_move_2, dt, vel, omega, time, dtime) { {...} vel[1]=velocity; } |
September 5, 2019, 13:09 |
Spyros
Rep Power: 7 |
Yes because either wise the one side of the interface moves and not both. I will provide the code and explain the procedure I am following
September 14, 2019, 13:13 |
#9 |
Spyros
Rep Power: 7 |
I've tried 2 tests. First one works ok but the second doesn't and I can't understand why.
The first one is a simple udf assigning a constant velocity for both sides of the interface and works great. The second udf calculates the average temperature and heat flux across the entire face of the interface of the solid and calculates the velocity of the motion when the temperature has exceeded a temperature value. The simulation crashes every time with the second udf the moment the temperature is reached and the mesh is to be moved with the calculated velocity. In the dynamic mesh zones window I set rigid body motion,motion attributes->interface_move1 for zone1 (the solid side of the interface) and for zone2 (the fluid side of the interface), rigid body motion, motion attributes->interface_move2. Any assistance would be much appreciated The codes are provided below. TEST1 #include "udf.h" double velocity; DEFINE_CG_MOTION(interface_move1, dt, vel, omega, time, dtime) { { velocity=-0.04; } vel[1]=velocity; } DEFINE_CG_MOTION(interface_move2, dt, vel, omega, time, dtime) { vel[1]=velocity; } TEST2 #include "udf.h" double velocity; double T_SUBL = 400.0; double H_SUBL = 27250.0; double HTC = 32.0; double dens = 2000.0; double area[ND_ND]; double areamag; double noface = 0.0; double BHFavg = 0.0; double BHFsum = 0.0; double tavg = 0.0; double tsum = 0.0; int tid; DEFINE_CG_MOTION(interface_move1, dt, vel, omega, time, dtime) { face_t face; Thread *thread = DT_THREAD(dt); tid = THREAD_ID(thread); begin_f_loop(face, thread) { noface++; F_AREA(area, face, thread); areamag = NV_MAG(area); BHFsum += (BOUNDARY_HEAT_FLUX(face, thread)); tsum += F_T(face, thread); } end_f_loop(face, thread); tavg = tsum / noface; BHFavg = BHFsum / areamag; if (tavg <= T_SUBL) { velocity = 0; } if (tavg > T_SUBL) { velocity = BHFavg / (dens*H_SUBL); } vel[1] = -velocity; Message(" THREAD=%i\n", THREAD_ID(thread)); Message(" BHF on surface=%g\n", BHFavg); Message(" AVG Temp=%g\n", tavg); Message(" vel=%g\n", vel[1]); Message(" velocity=%g\n", velocity); } DEFINE_CG_MOTION(interface_move2, dt, vel, omega, time, dtime) { vel[1] = -velocity; } |
dynamic mesh, fluent, udf, udm |
Fluent UDF urgent! Variable reaction rate | natantyt | Fluent UDF and Scheme Programming | 8 | October 17, 2021 04:35 |
Store a UDF variable | wadezaza | Fluent UDF and Scheme Programming | 6 | January 10, 2020 04:42 |
Can I change the variable in UDF via Fluent console or window without compiling? | swtbkim | FLUENT | 0 | July 12, 2017 23:15 |
List of variable using in UDF | Tleja | Fluent UDF and Scheme Programming | 4 | July 31, 2014 12:57 |
how to access a variable in DPM within a UDF | patrick | FLUENT | 13 | September 15, 2010 09:38 |
